Zum Hauptinhalt wechseln
ZTE Maven Earpiece Replacement
Toria Keyes
Toria Keyes und 5 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
10 Minuten
Mittel
If your ZTE Maven isn’t producing clear audio—distorted, intermittent, or no sound—through the earpiece, the earpiece may need to be replaced. Follow this guide to replace the earpiece.
The earpiece is a small audio device used to emit noise through the receiver. A faulty earpiece will transmit distorted audio to no audio through the receiver.
Before using the guide, be sure to check the receiver for any debris that may be interfering with the sound quality. The small clump of dust can be removed using a small dust blower. Also be sure to check the volume on the device settings to confirm that the problem is the faulty earpiece.
Be aware of steps 3 and 6 since they require you to work with small, delicate parts of the device, such as the 2mm screws and the ribbon cables. Be sure to turn off the phone and disconnect from any external power sources before removing or replacing any parts of the phone.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. ZTE Maven Earpiece Replacement, Back Cover: Schritt 1, Bild 1 von 2 ZTE Maven Earpiece Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Use your fingers to remove the back cover.
  2. ZTE Maven Earpiece Replacement, SIM Card: Schritt 2, Bild 1 von 2 ZTE Maven Earpiece Replacement, SIM Card: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove the SIM card from the right side of the device using a pair of tweezers.
  3. ZTE Maven Earpiece Replacement, Midframe: Schritt 3, Bild 1 von 1
    • Remove the seven 2mm Phillips #00 screws from the midframe of the device.
  4. ZTE Maven Earpiece Replacement: Schritt 4, Bild 1 von 3 ZTE Maven Earpiece Replacement: Schritt 4, Bild 2 von 3 ZTE Maven Earpiece Replacement: Schritt 4, Bild 3 von 3
    • Use an opening tool or fingers to separate the midframe covering the rest of the device starting at the top corner.
  5. ZTE Maven Earpiece Replacement, Front Camera: Schritt 5, Bild 1 von 3 ZTE Maven Earpiece Replacement, Front Camera: Schritt 5, Bild 2 von 3 ZTE Maven Earpiece Replacement, Front Camera: Schritt 5, Bild 3 von 3
    • Use a pair of tweezers to carefully detach the ribbon cable connecting the camera to the motherboard.
    • Using the tweezers or your fingers, firmly pull up to remove the camera from the phone.
  6. ZTE Maven Earpiece Replacement, Motherboard: Schritt 6, Bild 1 von 3 ZTE Maven Earpiece Replacement, Motherboard: Schritt 6, Bild 2 von 3 ZTE Maven Earpiece Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Detach the clips and cables and carefully and pull the glue pieces off the sides.
    • Remove the motherboard with your fingers.
  7. ZTE Maven Earpiece Replacement, Earpiece: Schritt 7, Bild 1 von 2 ZTE Maven Earpiece Replacement, Earpiece: Schritt 7, Bild 2 von 2
    • Disconnect the earpiece from the screen with tweezers or a spudger.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Toria Keyes
207 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 242
