Zum Hauptinhalt wechseln
ZTE Maven Front Camera Replacement
Toria Keyes
Toria Keyes und 3 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
10 Minuten
Mittel
If you need to learn how to replace the front camera on your ZTE Maven z812 smartphone, follow this guide. The front camera will need to be replaced if it has been damaged and can no longer take pictures.
The front camera on the ZTE Maven z812 is known as the main camera, located on the back interior of the phone. It has 5 mega pixels, featuring auto focus, video calling, and video sharing.
While following the guide, you will need to pay close attention to steps 2 and 4 because you will be working with small, delicate parts. Step 2 requires you to remove 2mm OEm screws to get to the front camera. For step 4, when prying the camera up with the tweezers, make sure to pull gently, ensuring that delicate parts around the camera (e.g ribbon and small screws) aren’t damaged.
Be sure to disconnect the phone from any external power sources before removing or replacing any parts of the phone.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. ZTE Maven Front Camera Replacement, Back Cover: Schritt 1, Bild 1 von 2 ZTE Maven Front Camera Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Use your fingers to remove the back cover.
  2. ZTE Maven Front Camera Replacement, SIM Card: Schritt 2, Bild 1 von 2 ZTE Maven Front Camera Replacement, SIM Card: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove the SIM card from the right side of the device using a pair of tweezers.
  3. ZTE Maven Front Camera Replacement, Midframe: Schritt 3, Bild 1 von 1
    • Remove the seven 2mm Phillips #00 screws from the midframe of the device.
  4. ZTE Maven Front Camera Replacement: Schritt 4, Bild 1 von 3 ZTE Maven Front Camera Replacement: Schritt 4, Bild 2 von 3 ZTE Maven Front Camera Replacement: Schritt 4, Bild 3 von 3
    • Use an opening tool or fingers to separate the midframe covering the rest of the device starting at the top corner.
  5. ZTE Maven Front Camera Replacement, Front Camera: Schritt 5, Bild 1 von 3 ZTE Maven Front Camera Replacement, Front Camera: Schritt 5, Bild 2 von 3 ZTE Maven Front Camera Replacement, Front Camera: Schritt 5, Bild 3 von 3
    • Use a pair of tweezers to carefully detach the ribbon cable connecting the camera to the motherboard.
    • Using the tweezers or your fingers, firmly pull up to remove the camera from the phone.
Abschluss
Toria Keyes
207 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 157
