Zum Hauptinhalt wechseln
ZTE Maven Loud Speaker Replacement
Karli Kennedy
Karli Kennedy und 3 weitere Mitwirkende
Zuletzt aktualisiert am 10. Feb 2022
5 Minuten
Leicht
If your ZTE Maven isn’t producing audio—distorted, intermittent, or no sound—throughout the device, the loudspeaker will likely need to be replaced. Follow this guide to replace the loudspeaker in a safe and efficient manner.
The loudspeaker is a small sound driver used to transmit audio to the speakers, earpiece, and external devices, such as headphones. A faulty or blown loudspeaker will transmit distorted audio or no audio at all.
Before using this guide, check the headphone port and earpiece speaker for any debris that may be interfering with the sound quality. Typically, a small accumulation of dust can be removed using a small dust blower. If the audio is only distorted through the headphones, be sure to also test various sets of headphones or auxiliary cords with your device to confirm that the faulty part is the ZTE Maven loudspeaker.
Step 2 requires you to remove eight 2mm OEM screws from the device to get to the loudspeaker on the back of the second covering. Be sure to turn off the phone and disconnect from any external power sources before removing or replacing any parts of the phone.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
  1. ZTE Maven Loud Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 2 ZTE Maven Loud Speaker Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Use your fingers to remove the back cover.
  2. ZTE Maven Loud Speaker Replacement, SIM Card: Schritt 2, Bild 1 von 2 ZTE Maven Loud Speaker Replacement, SIM Card: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove the SIM card from the right side of the device using a pair of tweezers.
  3. ZTE Maven Loud Speaker Replacement, Midframe: Schritt 3, Bild 1 von 1
    • Remove the seven 2mm Phillips #00 screws from the midframe of the device.
  4. ZTE Maven Loud Speaker Replacement: Schritt 4, Bild 1 von 3 ZTE Maven Loud Speaker Replacement: Schritt 4, Bild 2 von 3 ZTE Maven Loud Speaker Replacement: Schritt 4, Bild 3 von 3
    • Use an opening tool or fingers to separate the midframe covering the rest of the device starting at the top corner.
  5. ZTE Maven Loud Speaker Replacement, Loud Speaker: Schritt 5, Bild 1 von 2 ZTE Maven Loud Speaker Replacement, Loud Speaker: Schritt 5, Bild 2 von 2
    • Remove the loudspeaker from the cover using either your fingers or a spudger.
Abschluss
Rüste dich für deine nächste Reparatur
Alle in den Warenkorb legen
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 275
