Zum Hauptinhalt wechseln
ZTE Prestige 2 Back Camera Replacement
Maria Stock
Maria Stock und 5 weitere Mitwirkende
Zuletzt aktualisiert am September 29, 2021
7 Minuten
Mittel
This guide will help you replace the back camera in your ZTE Prestige 2. Before you start, check out our troubleshooting page that will help you decipher any basic problems before taking your device apart. Some reasons you may need to conduct this replacement is because the back camera may be scratched and/or cracked, therefore, making pictures blurry or spotting. Before beginning, make sure to power off your device completely and disconnect from any external power source.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. ZTE Prestige 2 Back Camera Replacement, Battery: Schritt 1, Bild 1 von 3 ZTE Prestige 2 Back Camera Replacement, Battery: Schritt 1, Bild 2 von 3 ZTE Prestige 2 Back Camera Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Back Camera Replacement: Schritt 2, Bild 1 von 2 ZTE Prestige 2 Back Camera Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery.
  3. ZTE Prestige 2 Back Camera Replacement, Back Panel: Schritt 3, Bild 1 von 3 ZTE Prestige 2 Back Camera Replacement, Back Panel: Schritt 3, Bild 2 von 3 ZTE Prestige 2 Back Camera Replacement, Back Panel: Schritt 3, Bild 3 von 3
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Back Camera Replacement: Schritt 4, Bild 1 von 3 ZTE Prestige 2 Back Camera Replacement: Schritt 4, Bild 2 von 3 ZTE Prestige 2 Back Camera Replacement: Schritt 4, Bild 3 von 3
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
  5. ZTE Prestige 2 Back Camera Replacement, Back Camera: Schritt 5, Bild 1 von 3 ZTE Prestige 2 Back Camera Replacement, Back Camera: Schritt 5, Bild 2 von 3 ZTE Prestige 2 Back Camera Replacement, Back Camera: Schritt 5, Bild 3 von 3
    • Use the iFixit opening pick and wedge it under the press fit connector beside the camera located at the top center of the device to pop it off.
    • Remove the camera.
    • The camera cable near the press fit connector is delicate, ripping it will cause permanent damage.
    • The base of the camera may be glued down which may lead to accidental ripping during removal. Use the flat end of a metal spudger to pry it up if necessary.
Abschluss
Maria Stock
524 Reputation
5 Anleitungen geschrieben
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 Mitglied von UW Stout, Team S1-G4, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 180
