Zum Hauptinhalt wechseln
ZTE Quest n817 Motherboard Replacement
Was du brauchst
  1. ZTE Quest n817 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 ZTE Quest n817 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 ZTE Quest n817 Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Ensure that the phone is turned off before starting.
    • Orient the device so that the inset on the right side of the device is facing you.
    • Insert the spudger into the inset and carefully remove the back panel.
  2. ZTE Quest n817 Motherboard Replacement: Schritt 2, Bild 1 von 2 ZTE Quest n817 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use the ribbon to remove the exposed battery.
  3. ZTE Quest n817 Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Use the JIS #000 screwdriver to remove the six 3.0mm screws placed in the back of the ZTE Quest.
  4. ZTE Quest n817 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Carefully pry open the back panel with the plastic opening tool.
  5. ZTE Quest n817 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Use a pair of tweezers to gently disconnect the ribbon cable connector from its socket.
  6. ZTE Quest n817 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Pull back the tape encasing the brown ribbon cable connector.
    • Remove the ribbon cable from its socket.
  7. ZTE Quest n817 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Unplug the flat-top connector by using a pair of tweezers to pry up each side before removing the connector from its socket.
  8. ZTE Quest n817 Motherboard Replacement: Schritt 8, Bild 1 von 2 ZTE Quest n817 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Disconnect the coaxial connector in the bottom right corner of the motherboard.
Abschluss
Eric Loureiro
582 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S3-G6, Peak Fall 2018 Mitglied von UMass Dartmouth, Team S3-G6, Peak Fall 2018
UMASSD-PEAK-F18S3G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 5
Letzten 30 Tage: 7
Insgesamt: 405
