ZTE ZFive G LTE Back Camera Replacement
Einleitung
Zu Schritt 1 der AnleitungIf the camera seems cracked and/or not functioning, this is a quick guide on how to remove the existing camera.
Was du brauchst
Pry open back cover of the device from the crease at the bottom left corner with an opening tool or fingernail.
Gently pry open the device body by tugging from the inside out, be sure to pull up and away from device.
Once body is removed, back-facing camera is placed at the top left corner of device.
Using an opening tool, pull up the tab of the camera wire ribbon.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using the blunt-nose tweezers, tug at the camera gently, switching sides to remove adhesive little by little, pull camera out gently.
