Zum Hauptinhalt wechseln
ZTE ZMax Pro Battery Replacement
Was du brauchst
  1. ZTE ZMax Pro Battery Replacement, Back Panel Assembly: Schritt 1, Bild 1 von 1
    • Flip the phone over so that the back panel of the phone is facing up.
    • Wedge the plastic opening tool between the black outer panel and the silver side panel.
    • Push down on the plastic opening tool to separate the back panel from the rest of the phone.
    • Continue to do this around all sides of the phone until the back panel has popped all the way off.
    • Removing the back panel may make loud popping noises which is normal.
  2. ZTE ZMax Pro Battery Replacement: Schritt 2, Bild 1 von 1
    • Using your fingers, slide the SIM card all the way out of the phone.
  3. ZTE ZMax Pro Battery Replacement: Schritt 3, Bild 1 von 2 ZTE ZMax Pro Battery Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
  4. ZTE ZMax Pro Battery Replacement: Schritt 4, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
  5. ZTE ZMax Pro Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
  6. ZTE ZMax Pro Battery Replacement: Schritt 6, Bild 1 von 2 ZTE ZMax Pro Battery Replacement: Schritt 6, Bild 2 von 2
    • Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
  7. ZTE ZMax Pro Battery Replacement: Schritt 7, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
  8. ZTE ZMax Pro Battery Replacement: Schritt 8, Bild 1 von 1
    • Flip the phone over so that the screen is facing up.
    • Wedge the plastic opening tool between the screen and the rear panel.
    • Push up on the opening tool to separate the panel from the phone.
    • Continue to do this around the entire phone until the rear panel is no longer connected to the device.
    • The rear case and screen are fastened tightly to each other. It might help to use the picks as wedges to keep the case and screen separated as you run the opening tool along the edges.
  9. ZTE ZMax Pro Battery Replacement, Motherboard: Schritt 9, Bild 1 von 2 ZTE ZMax Pro Battery Replacement, Motherboard: Schritt 9, Bild 2 von 2
    • Use the tweezers to peel off the yellow Kapton tape.
  10. ZTE ZMax Pro Battery Replacement: Schritt 10, Bild 1 von 1
    • Use the plastic opening tool to remove the connectors on the motherboard.
  11. ZTE ZMax Pro Battery Replacement: Schritt 11, Bild 1 von 1
    • Use tweezers to remove the antenna. The antenna comes up on the right side of the phone, by the battery, and is attached to the motherboard.
  12. ZTE ZMax Pro Battery Replacement: Schritt 12, Bild 1 von 1
    • Using the #00 Phillips screwdriver, remove the 3.0 mm screw located on the right edge of the phone, above the battery.
  13. ZTE ZMax Pro Battery Replacement: Schritt 13, Bild 1 von 1
    • Wedge the plastic opening tool underneath the motherboard which is located at the top of the phone.
    • Push down on the plastic opening tool, lifting the motherboard away from the phone.
    • Continue to do this around all sides of the motherboard until it is fully removed from the phone.
  14. ZTE ZMax Pro Battery Replacement, Battery: Schritt 14, Bild 1 von 2 ZTE ZMax Pro Battery Replacement, Battery: Schritt 14, Bild 2 von 2
    • Use tweezers to peel off the tape at the bottom of the phone.
  15. ZTE ZMax Pro Battery Replacement: Schritt 15, Bild 1 von 1
    • Wedge the plastic opening tool under the charging port board at the bottom of the phone.
    • Push down on the plastic opening tool so the board pulls away from the phone.
    • Continue to do this around the charging port board until it comes all the way off the phone.
    • The board is glued to the case so make sure to work around all edges to ease removal. Trying to pull it away from one edge can cause damage to the board.
  16. ZTE ZMax Pro Battery Replacement: Schritt 16, Bild 1 von 1
    • Use a heat gun to heat the adhesive under the battery.
    • Heat the battery for 1 minute then check if it is pliable. If needed, heat in intervals of 10 seconds until the battery can be removed.
    • Over heating the battery can cause the battery to explode. Exercise caution heating the battery.
  17. ZTE ZMax Pro Battery Replacement: Schritt 17, Bild 1 von 2 ZTE ZMax Pro Battery Replacement: Schritt 17, Bild 2 von 2
    • Use a nylon spudger to pry the battery from the phone.
    • The battery may bend a little during removal which is normal. However, make sure the battery doesn't bend too much as that can make it dangerous. If it looks like it's folding, try prying it from a different angle.
    • Avoid using metal tools to pry the battery out of the case as it can pierce the battery.
    • Contents of the battery are extremely polluting to the environment. Do not throw it away in the recycling. Instead, try finding out what your local community does to dispose of batteries.
    • After removing the battery, the adhesive will not have as strong of a hold on the new battery. This should not be an issue. However, if the adhesive strength is negligible, you can consider buying adhesive and applying it before inserting the new battery.
Abschluss
18 weitere Personen haben diese Anleitung absolviert.
Nicholas Leacox
1.739 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S17-G3, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G3
4 Mitglieder
16 Anleitungen geschrieben
14 Kommentare zur Anleitung
This is much more difficult than it is depicted; while I’m not an electrician, I’ve acquired skills as a sailor over the past 8 years. Damage to the device is nearly guaranteed. I would NOT recommend trying this operation.
Getitup7 - Antwort Teilen
Have you actually tried? With the proper tools and care it doesn’t seem that difficult. But then I was a computer tech and repaired laptops. For anyone inexperienced or lacking patience, you’re probably right.
alan scott - Teilen
It’s actually pretty easy. I’m guessing your main concern is ESD… You can avoid electrostatic discharge by using the proper tooling and ESD mats.
christopherpessetto - Teilen
The instructions were good. Please note the cable under the yellow tape is very thin and not really visible against the backdrop. Mine tore and made camera not function correctly.
Deborah Scoggins - Antwort Teilen
Also note, I couldn't remove the last screw off the motherboard. It was too tightly inserted and was stripping by attempts. I turned my phone face down with gorilla glass against a heating pad on a low setting for just a few minutes to warm the adhesive on the battery. Keep the top section with the motherboard off the heating pad. This was the easiest thing to remove. Use a plastic spatula not a metallic one.
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 51
Insgesamt: 13,883
