iMac G5 20" Model A1076 Hard Drive Replacement
Was du brauchst
Remove the following three screws:
One shouldered 12.4 mm Phillips.
Two 7 mm T10 Torx.
Lift the hard drive slightly and disconnect the hard drive thermal sensor connector.
Insert the flat end of a spudger into the gap between the SATA data connector and the hard drive.
Twist the spudger to separate the SATA data connector from the hard drive, then disconnect it from the hard drive.
