Diese Übersetzung enthält möglicherweise noch nicht die neuesten Änderungen der Original-Anleitung. Hilf mit, die Übersetzung zu aktualisieren oder sieh dir die Original-Anleitung an.
Einführungsvideo
无论你使用什么工具,你需要确定你把整个显示屏拉起来了。
如果玻璃开始从塑料分离,如图一所示,在塑料框架和金属手机之间滑动塑料小撬棒,以撬出后机壳的金属夹。
将蓝色手柄拉向铰链以解锁反向钳的手臂。
将反向钳手臂滑过 iPhone 的左边缘或右边缘。
将吸盘放在靠近 iPhone 底部边缘的位置——一个在正面,一个在背面。
向下推吸盘以将吸力施加到所需区域。
请务必在维修继续前断开电池,如果不这样做的话,有时会导致手机运行太热和/或与触摸敏感问题。
当前面板组件底部和侧面夹扣被撬起后,拉动组件的底部使之远离后壳。
缓慢提升前面板组件跟后壳体成约90度。
捏住露在外面的透明塑料标签并向右拉,这样电池就会完整地从机身上脱离。
如果你无法顺利地取下电池,可以借助iOpener工具,或者使用吹风机加热iPhone背部对应电池的区域来软化粘合剂。
拉胶的塑料标签强度不高,有可能会被扯断。如果你在取下电池前弄断了标签,可以按照以下步骤补救。
将新的更换配件件与原始配件进行比较 —— 在安装之前,你可能需要转移剩余配件或从新配件上移除粘合剂背衬。
要重新组装你的设备,请按相反顺序执行上述步骤。
将你的电子垃圾带到R2或e-Stewards认证的回收商。
维修没有按计划进行?查看我们的社区以获取故障排除帮助。
3775 weitere Nutzer:innen haben diese Anleitung absolviert.
50%
Hier starten ›
Angehängte Dokumente
363 Kommentare
When I finished installing the battery, I put everything back together the way it should be but I have two small problems.
Problem 1: The top of the screen doesn't sit the way it did before I opened it. It sticks out more at the top than the bottom. I'm not talking much, maybe fractions of a MM extra?
Problem 2: The screen isn't as responsive as before. When I'm typing, it sort of lags and then it catches up really fast, sort of like when they phone is "busy" and then it catches up with what you're typing. However, it's not only during typing but scrolling and when tapping the screen. It is generally overall less responsive.
Any ideas?
If others have this problem like I did too when first changing the batter. Here's the answer not in the steps in the guide:
When reassembling the case after replacing the battery and closing the case you have to do the following. The top of the screen (where the cables to the LCD screen are connected) has to be slid in first, before settling in the rest of the case, so that there is no "bumb" on the top of the case. If you don't slide in the case correctly, you will get screen artefacts (after effects, ghosting) when pressing the screen in normal use. You'll notice this immediately and should notice it by the frame not being even on the top.
Fix: Just reopen the screen top, slide the screen frame top first in place, then close the rest of the case and test. Should be ok.
Super easy! I am not used to repair things on the regular but this was a breeze. The video was the perfect companion. Hardest part was removing the screen, then reapplying the cover for the three connections towards the top of the phone. The piece didnt seem to sit right, but jiggling it around a little helped and worked like a charm!
While trying to gingerly open a gap with the suction cup, my entire display assembly released all at once and flew up. I think I must have damaged a trace on the flex connector going to the backlight, since I now have hot spots along the top of the display and it seems half of the what-seem-to-be 8 LEDs are dead. Brightness at full is noticeably lower than a friend's iPhone 5.
