Zum Hauptinhalt wechseln
Dell 19" LCD Monitor, charcoal gray in color, released in 2004.
Screen not activating start button flashing
Monitor would not 'tun on'.Start button on bottom right hand corner was flashing and screen was blank.
Unplugged all leads and power to PC to get this going.
Don't know why this occurred.
Any ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Warren, the flashing LED can be an indication that your monitor is having power issues. Recheck your connections, if all of them are okay, disassemble your monitor and check the caps on the power board. Use these guides to work on your monitor. It does sound like you are having a few failed capacitors. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 0
Try using a different VGA cable.
Bewertung 0
1 Kommentar:
Thanks ,not the answer I was hoping for.but sounds correct.We managed to get it going all night then this morn same.but can't clear it this time.had a long hot summer so maybe board dried out etc.Thanks again
von
i think symptom due to monitor.
Bewertung 0
I have a windows 11 monitor but the light by the intel core i7 is blinking and my screen is just black and idk what to do.
Bewertung 0
Antwort hinzufügen
Warren wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 23,224
