Zum Hauptinhalt wechseln
The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
My car is losing power and killing my battery?
I need fuse box diagram to troubleshoot my connections so, I could see the fuse inputs in my 93 Honda Accord SE. I got a fuse box diagram for 93 Honda Accord but it is different from mine. Please help I'd appreciate it. Thank you
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Is this closer to the fusebox in your car? http://i6.photobucket.com/albums/y205/pr...
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Its your alternator is bad
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Two places to start. First get a volt meter and measure voltage of battery, then start car and measure again.
Running voltage should be 13+, battery itself 12.8 or more. A car this age will likely start on a dying battery (under 12.2ish) but should stay running if alternator is charging.
Second- go to any auto parts store and they will run a quick check for free. This should answer most any other questions.
It is possible that you have a bad relay but unlikely. These can often be tested by swapping a light (pop up headlights?) or AC relay to the charging slot.
von
Antwort hinzufügen
jsandoval7988 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 25
Insgesamt: 283
