Zum Hauptinhalt wechseln
Released in November 2013, this model of the HP 2000 series is the perfect device for those on a budget, but don't want to sacrifice performance.
Why is my computer very loud?
My laptop has been running fine since I bought it a few months ago but all of a sudden it has started getting very loud and hot while on. The fans have been running nonstop. Is there anything I can do so that it will quiet down?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Conor Most, you will have to find out why it does that. Check your computer resources and see what the total demand is. Make sure that your laptop has unobstructed airvents. Make sure that those vents are clean. If all that is normal you will have to disassemble your computer and take a look at the Fan. I would replace it for sure. Check the heatsink and assembly and replace the thermal paste. download the service manual from here Page 73 will tell you how to replace all that . Hope this helps, good luck
War diese Antwort hilfreich?
Bewertung 3
It's under warranty, let HP fix it or you'll void that warranty!
Bewertung 0
Antwort hinzufügen
Conor Most wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 587
