Zum Hauptinhalt wechseln
Key has detached from keyboard
How do I (can I?) replace a broken key on the keyboard? It is the ]} key.
Update
Hi, I can see now how to replace the key! Great, but where can I purchase the replacement part (the plastic hinged frame, which has a missing top hinge pin)?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Could you tell us exactly how the key is broken? It will help us help you. Ralph
von
Something small like that might best be found on eBay.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Keys are user replaceable
If the tangs are broken off you'll need a new key. If not one end (side or bottom) sides under a tang on the keyboard, the hinges pop into pins on L & R.
http://www.youtube.com/watch?v=JjRTQIfVT...
Good Luck,
N.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Great link if the question asker knows to click on it. Please make your links more obvious. You usually have very good answers but we aren't dealing with power users here. You still get an upvote from me.
von
Thanks Machead3!!!
That worked perfectly and was a piece of cake!
I should have guessed there would have been some answers on YouTube.
von
Yes, keys are definitely replaceable. In fact, there are online shops that specialize in such thing. Check out http://www.laptop-keys.com to find laptop key replacement and repair kits.
Bewertung 0
Antwort hinzufügen
billgaskins wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,918
