Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
20 Fragen Alle anzeigen
Why Will The Logic Board Not Go In?
Hi, I am replacing the screen and home button of my iPhone 4. I dismantled fine, no problems, but I cannot get the logic board to go back in the phone. There is a small gap between the back of the logic board and the phone. The logic board bends and flexes if you try and push it in the middle.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Make sure that the battery removal flap and all of the connectors are out of the way. Also remember to place the logic board in top first and that it slips under the top lip of the chassis.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
I am using this i fixit guide : iPhone 4 Home Button Austausch.
It may be worth mentioning that I found it tricky getting the speaker enclosure to stay down, as it kept popping out. It is now held in well at one end by a screw, but at the end that it joins with the logic board, the logic board has to go in before you install the screw. As a result of this the speaker enclosure is slightly out at one end.
von
I added all of the screws and gently applied pressure until it went down. iPhone now works. Cheers.
von
Antwort hinzufügen
Michael wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 64
