Zum Hauptinhalt wechseln
A Wi-Fi and NFC capable CMOS camera first released in March 2013. Identified by model number EV-NX300ZBQUUS.
20 Fragen Alle anzeigen
Why does the image freeze in capture mode?
Hello,
I have had a NX300 since a couple of years. A couple of weeks ago it fell (it was in a padded bag) a few feet to the ground. After that it was only showing a black screen (with menus still visible) in capture mode. It also doesn't turn off when flipping the switch to off mode. The shutter is not closed, since I had read elsewhere that that might be the problem.
I discovered that if I enable 'sensor cleaning', then it actually does show an image after turning it on, but after about 4 seconds the image freezes. After freezing I can get it to power off normally.
Does anyone know what the problem might be?
Thanks in advance!
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar:
I have the same problem as well! What's funny is that this problem happened also because I dropped my camera. I just wanted to let you know that I will be going to a camera repair shop soon and see what the problem is, if they can even find a solution.
von
Einen Kommentar hinzufügen
1 Antwort
Did you ever find a solution? I have a wedding in 8 days and this is my only camera!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
JF wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 331
