Zum Hauptinhalt wechseln
The Kodak EasyShare C913 is a 9.2 MP digital camera.
Camera not turning on.
I got this camera for my wife. She's been using it without any problem. But after she put it away for a while, the camera would not turn on even with new batteries installed. She probably did not use the camera for 3 months or longer with the batteries in it. Did the batteries ruin it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
4 Kommentare
Thank you all for your suggestions, but the camera still does not turn on because I don't think it's the batteries. There was no corrosion at all. It might be a short circuit in which case I have no way of fixing it except to take it apart. Even if I did that, I would not know what to look for.
von
Team - believe the common issue that many customers experience with this model Kodak camera is that new batteries don’t resolve the issue and there is no obvious corrosion present to clean up, so please advise what else the problem can be for the majority who don’t have a leaky old battery issue as the reason the camera (in good condition) won’t power up with new batteries. TY.
von
One of the lower battery terminal touch points has become detached. This is located through the plastic body and is not easy to reinstall.
von
This must be a common issue with Kodak. Pathetic
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Have you tried a water and baking soda mix. Using a Q-tip to clear up the acid?
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
NINO Sylmar, just to clarify those batteries do not leak acid. You most likely were using standard alkali batteries, there is no acidic electrolyte. The substance that leaks from those batteries is potassium hydroxide which is alkaline and can cause severe corrosion. Clean it properly with a qtip and some vinegar. Then dry it of with a qtip and some sterile water, rinse with isopropyl alcohol.
Bewertung 4
2 Kommentare:
cleaning the battery terminals worked just like a miracle ! I was ready to break the camera until I tried this.
von
Batteries had been in the camera for at least two years, tough even to open the access. inside was white! Took an hour to remove them. Nothing worked so I tried this idea with vinegar, in 15 minutes all the contacts were sparkling. I put in new AAs and experienced this same miracle!
von
Antwort hinzufügen
NINO Sylmar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 72
Insgesamt: 5,117
