Zum Hauptinhalt wechseln
Die PowerShot S110 verfügt über einen 12,1-Megapixel-Hochempfindlichkeits-CMOS-Sensor, den DIGIC 5-Bildprozessor, 12-Bit-RAW+JPEG mit mehreren Seitenverhältnissen, ein 24-mm-Weitwinkelobjektiv mit f/2,0-Blende und 5-fach optischem Zoom sowie ein schlankes, taschenfreundliches Gehäuse.
Is it possible to replace the flash light?
Because the flash light is not working I want to replace it but I don't know if it is possible. I can't find anything about replacing the flash light and I don't wanna open the camera without knowing it. I can't find a replacement item either.
If anybody knows anything about this, please let me know, thanks a lot.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Yes, it is possible.
You have to exchange the "Canon PowerShot S110 FLASH ASS'Y Replacement Repair Part".
This is hard to find but i got it on http://www.ebay.com/itm/Canon-PowerShot-...
Use the dis-assembly instruction for the display and remove further the copper foil under the display to find 2 further screws on the camera backside, remove these and also one screw on the assy frontside. Carefully disconnect the foil plug of the build-in assy and you can easily do a drop-in replacement of the assy.
My camera is again working.
Never manually push-in the flash of the camera. This will destroy the camera flash assy.
Good luck ;) !!
War diese Antwort hilfreich?
Bewertung 2
i also have this problem with the s100..flash will not fire..the flash raises up..the program is set on flash..however, will not fire? have no idea why? if someone can give me advice to fix the flash..please give to correct my problem...thank you..
Bewertung 0
Antwort hinzufügen
justtrying wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 29
Insgesamt: 2,216
