Zum Hauptinhalt wechseln
The Asus MeMO Pad 7 ME170C is a touch screen tablet manufactured by Microsoft and released in August of 2014. It has a screen resolution of 1280 x 800. Identified by model number K017.
10 Fragen Alle anzeigen
USB charging port got broken, need to replace.
I have one ASUS MeMO Pad 7 – ME170CX ; 7-inch, 16GB. Charging USB port got broken. Its needs to be replace. Can any one tell me how to fix this with details procedure. Or if any one can fix it for me?
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
If it's any help, I googled Asus Memo Pad 7 charging port, and the replacement appeared for purchase.
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi, as of right now we do not have a guide on how to repair the USB port. Hopefully, in the future there will be a guide for this. If you feel confident and have done research on the device, you can use the first step of any of our guides to open the device exposing all the components and see what you can do to fix the USB port. I advise extreme caution if you do decide to open the device as there are many variables to consider. Those cautions are noted in the first step of all our guides. I hope this helps.
War diese Antwort hilfreich?
Bewertung 1
This requires hot air soldering experience, and this particular pad is complicated by the fact the camera is right next to the port which could cause issues on repair.
I have so far not been able to source the parts for this repair.
Bewertung 0
Antwort hinzufügen
Tushar De wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,275
