Zum Hauptinhalt wechseln
The Asus Transformer Pad TF103C is a 10.1 inch Android hybrid tablet released in June 2014. It is specifically for entertainment use with wifi ability.
13 Fragen Alle anzeigen
My asus screen is flickering. How do I fix it?
On my relatively new Asus tablet,(I got it on the first of April), the screen keeps flickering to Gray with different coloured bars across it. I've reset this tablet, so I know that it's not a virus. The screen seems to flick randomly, not just when I move it or connect it to my charger. It does flick when I put in my headphones and connect the keyboard. Why is this happening, what type of problem is this and how can I fix it?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
why would they say they are number in quality if they have issues like this.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I have had the same question in my mind. They could not fix the flickering display problem. Their service centers are also not trained for taking care of this.
von
Sounds like a damaged LCD flex or even damage to the actual LCD itself. Electrical interference would occur when connecting anything to it which might cause a flicker to a damaged flex or LCD. If it hasn't been dropped, this malfunction should be covered by your warranty
Bewertung 0
2 Kommentare:
Would there be any way to fix it myself? (Sorry if it's a stupid question)
von
Absolutely!
Here is the guide
Asus Transformer Pad TF103C Screen Replacement
It looks quite involved but there don't seem to be any tricky steps. The most difficult part about a repair like this is staying organised. I usually put every single screw or part in a line or 2 in order as I take them out and work backwards to put it back together
There is a replacement screen available here:
http://www.ebay.co.uk/itm/ASUS-TRANSFORM...
Or you may find one cheaper elsewhere or more local to you. The digitiser and LCD look like they can be separated easily so you shouldn't have to worry about buying a complete front assembly
von
Antwort hinzufügen
lylytabbylover wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 10,850
