Zum Hauptinhalt wechseln
HP Envy TouchSmart 15, model 15t - j000. Release year 2013.
20 Fragen Alle anzeigen
No power in laptop, possibly shorted chipset
OVERVIEW:
I open up my laptop quite frequently as I go from new owner to upgrader, gradually replacing the wireless or storage space. On time I got lazy and left the battery plugged in while I went in and poked around. Now the laptop won't turn on.
PROBLEM: Laptop does not power on, unresponsive in general.
CAUSED BY (?): I might have shorted out a component by leaving the battery in while tinkering.
OTHER INFO: The charging light comes on when plugged into the wall adapter, but if on battery mode no lights come on when the power button is depressed (no light codes to read)
POSSIBLE SOLUTIONS: I replaced the power button which unsurprisingly did not work. Before purchasing any more components I need to isolate the issue. I need to use some multimeter tricks to identify the full damage to my components before continuing.
REQUESTING: A helpful tip, guide, link to an existing guide resource, etc. for how to correctly use a multimeter to indetify dead components, how to visually ID dead circuit components, etc.
Thank you for any response!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Try a static discharge this is a common result of not powering down a laptop or computer when working on its hardware. You may also have pooched out your ram
1. Disconnect the power cord
2. Remove the battery
3. Hold down the power button for 30 seconds, then release for 30 sec and then hold down for another 30sec
4. Plug in power; replace battery and power on laptop.
If this causes no Joy try this.
Remove memory and reinstall one stick at a time, if there are more than 1 DIMM of RAM, try each stick in each slot one at a time to see if the memory is ok and to determine if one of the memory slots is bad.
In your case you may want to try completely new memory
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
John Gray wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 2,062
