Zum Hauptinhalt wechseln
Der Bose SoundLink Mini II ist ein kabelloser Bluetooth-Lautsprecher mit kompaktem Design und qualitativ hochwertigem Ton. Das Gerät wiegt etwa 680 Gramm und seine Bluetooth Reichweite beträgt etwa 9 Meter. Das Gerät kam nach dem 26. Juni 2015 auf den Markt und trägt die Modellnummer 725192-1110.
How to attach rubber pads at the bottom?
I took out the rubber pads at the bottom of the speakers to try out the charging cradle and I'm finding attaching it back hard.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Struggling with this as well - the rubber tongue won't go in... Any ideas?
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
After a long struggle I finally just cut the tongue off. I then put the silicone foot pad back on the speaker and after months of using and moving it the pad hasn't come off. Get a pair of scissors, take a deep breath, and cut that thing off!
von
Thanks for re-assuring!
Eventually after a similar struggle that's what I already did :) Looking at other instructions, it seems that one needs to remove the back grill and then use tweezers to catch the edge of the tongue to pull it in. Since the grill is held by a sticky tape, I think it will be quite challenging to fit it back in a way that it will look like new - in fact, none of the instructions show how the device looks after assembling.
So I well decided that the tongue is not that functional and indeed the rubber pad is held well with it's edge grooves.
von
Antwort hinzufügen
Francisco Santiago wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 2,813
