Zum Hauptinhalt wechseln
Reparaturanleitungen und Support für die EOS 70D, eine 2013 von Canon veröffentlichte DSLR-Kamera. Dieses Modell lässt sich anhand der Modellnummer DS126411 identifizieren.
Display screen shows "white noise" image after taking picture
I hadn't used my Canon 70D in about a week. Then powered it up. Everything looked fine. When i pressed the shutter and took the picture nothing but a pixelated white image appeared on my display. I cleaned the sensor manually, checked the battery, All good. The same thing happens when I switch to video mode. I guess my question is, Do i need to replace the entire display as I've seen on a couple YT videos? Or is something else going on here? Thanks for any advice..
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare:
Hi Mark, I might do a litte bit of trouble shooting. For example: Have you tried taking a picture while the LCD screen is switched off? Do you then get the same result? Do you have the possibility of using a different lens? Is the problem still there? Have you taken out the batteries for a minute an put them back in? Also, try to take a picture with the cap on the lens. Just some thoughts...
von
Steffen, Thank you so much for your suggestions. I did try removing the battery for over a min and replaced it with an official Canon battery (the original one). I flipped the LCD screen around so it faced the back of the camera and was not visible. Still no luck in producing a digital image. I don't have another lens at the moment but will be able to borrow my daughter's soon. I will still continue to research the problem. Thanks again. Mark
von
I have this same problem. It started yesterday. My camera -- a 70D -- has not suffered any trauma. I have tried the steps suggested by Steffen. Additionally, I have cleaned the lens and camera body contacts, used the camera to clean the sensor and have reformated my card. This is my first problem with this camera after a year of use. Also, I did get some error messages yesterday, just before the camera stopped working altogether -- I think because the battery died. Alas, I did not note any identifying numbers. At the time, I assumed it was a flash error. That has happened in the past when the pop-up flash hits the brim of my ball cap.
von
My 70d is experiencing the same issue. I used it a few months ago put it away when it was working perfectly. This time when i took it out all the pictures are just like a old black and white TV without any signal!
Any ideas?
von
Einen Kommentar hinzufügen
1 Antwort
Same thing has happened to my 70D :-(
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
This happened to my 70D today. What's going on???
von
Antwort hinzufügen
Mark Haddon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 1,959
