Zum Hauptinhalt wechseln
My Xbox 360 wireless controler wont do anything.
So I got a used Xbox off Craigslist and some of the remotes had battery acid corrosion on them. So I clean them with lemon juice and now nothing happens when I try and turn them on nothing happens. NOTHING!!!!! Please help!!!!!
Ist dies eine gute Frage?
Bewertung 1
3 Kommentare:
Were are the battery contacts and how do I know if they are bad? Does it make a difference if I'm using AA's or not?
von
Yes you need to use aa batteries, along with the battery shell that the batteries fit in to. The contacts are just the metal part where the batteries sit on top of. Make sure they are not corroded or bent otherwise the controller won't be getting power from the batteries
von
Ok how do i know if the battery contacts are bad
von
Einen Kommentar hinzufügen
1 Antwort
Hi you would need to dismantle the controller and clean the battery contacts with isopropyl alcohol and a toothbrush, if they are really bad and that doesn't work, then you would need to buy replacement ones
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
The battery contacts are the metal part where the batteries sit and if they look corroded then most likely you would need to purchase replacement ones and solder them on
von
Antwort hinzufügen
Parker Collins wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 1,159
