Zum Hauptinhalt wechseln
Repair guides and support for the third-generation 5D, a DSLR camera released by Canon in 2012.
18 Fragen Alle anzeigen
err 40 at power up
Hi,
my camera 5dmk3 power up correctly but it returns err 40. could it be an issue related to the PCB bottom or the DC-DC PCB, what's your opinion regard it?
I tried to load / access to your canon eos 5d mark 3 parts catalog , but it does not loaded. Is it in progress or is it not available?
Thanks in advance
Giorgio
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
Giorgio Ba err40 is most commonly an electrical error. It can be related to the battery (first thing I'd replace) but also with the flex cables going to the DC-Dc board etc. Not sure why the parts catalog does not download for you. Added it on here==>>EOS 5D Mark III Parts Catalog
War diese Antwort hilfreich?
Bewertung 1
Hi Giorgio.
Did you find out what was wrong?
Rune
Bewertung 0
Hi,
Problem- A power malfunction have detected.
DIY- Turn off the camera and after 15-20 seconds power it on.
Bewertung 0
Was you in wet condition (moisture, raining, etc.) and after that camera´s went to faulty?
Bewertung 0
The bottom flex cable, between the bottom and main board, if installed backwards, can cause this error. The end with a B on it should be on the bottom board.
Bewertung 0
Antwort hinzufügen
Giorgio Ba wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 23
Insgesamt: 4,091
