Zum Hauptinhalt wechseln
The second generation (chassis model L30) was an American market-only version, again styled by Nissan's California design center under Doug Wilson through 1994 (design freeze in 1995).
8 Fragen Alle anzeigen
How do I install an ac compressor?
How how do I install an AC compressor on my 2000 Nissan Altima. I have never done it before so I need a step by step tutorial
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
there is special equipment needed to do an air conditioning compressor unit. the tools required will make it a job best left to a professional or at least someone with the tools . installing the pump is simply a matter of removing the bolets holding it on and putting the new one in also removing the to hoses and electrical connectors. thats the easy part once you put it together you have to purge the system of moisture by pumping out the air so you will need a vacuum pump . you will also need to replace the condenser. whenever you open a air conditioning system you need to replace this . Once youve purged the moisture you need to test to see that theres no leaks in the system and only then if theres no leaks will you be able to put the freon into the system . This is a very informative video
https://www.youtube.com/watch?v=95RdGLFI...
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Monique l wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 1,827
