Zum Hauptinhalt wechseln
Bei Nerf Guns, die offiziell als Nerf Blasters vermarktet werden, handelt es sich um Spielzeugwaffen von Hasbro, mit denen Schaumstoff-Darts und in manchen Fällen Schaumstoff-Bälle abgeschossen werden.
20 Fragen Alle anzeigen
The Judge Nerf Gun
I just opened my "The Judge" and in my first Nerf battle, the slide on the bottom of the gun jammed and now it won't prime at all. It slides back, rotating the barrel, but it will not continue the cycle and prime the spring inside. I think the spring inside is misplaced inside, and I tried to take it apart, but the smallest screwdriver we have here is slightly bigger than the screw(s). Could someone please tell me what screwdriver size I need, and give me advice? Thank you.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Hey, sorry for the bump, but did you manage to solve it? I have the same problem. However, I think I will buy another one. My neighbors love a lot to play with them and I started to play because of them. To have a more interesting game, I bought a fully automatic nerf gun from https://blasterpiece.com/best/nerf-machi..., and everybody fell in love with it. Their birthday is tomorrow and I think they will be happy with my gift as I bought them the same nerf guns. I really hope that nobody bought the same gift because it will be very uncomfortable and I also will not feel comfortable.
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
I had this issue also with the pump handle. I used a #1 -3inch screwdriver. There are two screws inside the Shell that you have to take out also, so before removing screws take the barrels out first. Use a pair of pliers to pull each of the three barrel pieces out. Then you have to take off the Shell that is clipped in. Use a couple small flat tip screw drivers to push in between where the clips hold to the main part of the gun then pull the Shell little by little off. That's the easy part. Now after unscrewing all the little screws carefully without stripping them, open the gun from the bottom. The clear top will stop you from fully opening the gun so take your screw driver and push the clear circular tabs up from inside of the gun up. Pull the clear part, from the back, up and rotate it forward to come off. After I got to this part I noticed that the issue was not in the pump handle. Double check the pump handle. Hopefully that is all you have an issue with. My problem was in the piston part itself. If you find that that's your problem also you might want to put it back together and return it. I took apart the piston. It will explode when you open it. Three screws and four easy to push in tabs is all it takes to open the piston. There is no way to take a picture of the piston before it explodes. There are three springs that are held loosely to loose parts inside the Piston that have to stay loose for sliding purposes. I glued the spring ends to the small pieces and the other end of the springs to the piston main piece.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
I am stuck now on where a little white piece looks like a comma goes. I put the Piston together without that piece and the white cog that connects to the little gear in the piston gets stuck so that piece had something to do with the gears and the track inside the Piston pushing a small spring part up. After about 6 hours of tinkering I'm about done. I recommend using two people to put this thing together or even better buy a different gun. When the gun works it will be a fairly weak blast due to the O-ring in the piston not creating a full seal. I made the seal full by putting a couple of my daughter's tiny rubber bands under the o-ring to expand it. 4 tiny rubber bands gives a good seal without a difficult time using and pulling. I wish you the best in your nerf judge experience. Now I'm off to get a different gun for my son and throw this one in the trash.
von
The white comma piece actually just holds the clear top piece into the main frame.
von
Maybe try different types of screwdrivers?
I actally am a skeptic.
Bewertung 0
precision set of screwdrivers are a must for what your trying to do
Bewertung 0
Antwort hinzufügen
Jonathan Guerrero wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 2,563
