Zum Hauptinhalt wechseln
The first Altima was produced in June 1992, as a 1993 model. All Altimas were built in Smyrna, Tennessee, until June 2004, when Nissan's Canton, Mississippi plant also began producing the model to meet high demand.
5 Fragen Alle anzeigen
Steering wheel vertical tilt lever / arm.
You lower the arm to tilt the steering wheel. After adjusting the vertical height of the steering wheel, you raise the lever back to the top-most position and the steering wheel locks in place. Recently, I had to change the ignition lock (where you insert the key to start it) and falsely assumed I'd have to remove this arm to lower the whole steering column to get to the lock (i had to drill out some rivets...). I replaced this arm in (as far as I can tell) the exact same way that I removed it, however, it will no longer lock in place and the steering wheel keeps lowering its self while I'm driving and even with the arm in the upright position, i can lower the steering manually with one finger and very little effort.
How can I fix this and make it (and the steering wheel) STAY up top in the highest raised position??
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
When you removed the arm you had to have loosened off the lock if the lock no longer holds the wheel you need to tighten up the lock . Dont over tighten or you wont be able to move the wheel at all . hope this helps
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Mitchell Turner wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 975
