Zum Hauptinhalt wechseln
The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
Car turning over, not starting. Oil on spark plugs.
My 92 Honda Accord has been sitting for a few months, go to start it and it turns over, but doesn't start up. Also, there was oil on the spark plugs, cleaned them up and the car started. A day later, I go to start it again and it doesn't start up. Over the past few days, sometimes it will start up and other times it won't. Battery is fine and exhaust smoke is fine as well. It does have gas in the tank. I think it's either gas filter needs to be cleaned/changed or the oil on the spark plugs is causing the issue. I am not much of a car guy and I don't know how to diagnose any problems further.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@stuart_as When you pulled the spark plugs was there oil in the spark plug holes before pulling the plug ?If so the valve cover seals are gone and the plugs are being drenched in oil . to remedy the problem you need to replace the o-rings in the valve cover spark plug passages. when drying up the plug its a good idea to put dielectric gel in the spark plug boot as this will help seal out the moisture. but oil filled plug shoots will keep the car from running . Hope this helps
War diese Antwort hilfreich?
Bewertung 3
8 Kommentare:
Yeah, there was a bunch of oil in the holes, as of now it's not as bad but there is still oil in there. Will replacing the o-rings be a hard/expensive fix?
von
If your handy you can do it yourself this video may be helpful .https://www.youtube.com/watch?v=u8Eti-iO...
von
try to clean up as much oil as you can before the plugs are removed
von
most machanics will charge about an hour to do the job so depending on there shop rate
von
this is a better video . Its for a newer Honda but its basically the same https://www.youtube.com/watch?v=_2Lnn6Fj...
von
3 weitere Kommentare anzeigen
Antwort hinzufügen
Stuart Smith wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 21
Insgesamt: 13,414
