Zum Hauptinhalt wechseln
Hier findest du Reparaturanleitungen für Nähmaschinen.
20 Fragen Alle anzeigen
Repair manual Bernina 1001 or 1000-series?
Having problems with the bottom thread; on the top a straight stitch, on the bottom a rather loose "S"-shape bobbin thread. Tried all kinds of upper- and bobbin-tension settings, needles, threads. Hook seems to be on time; no "pick-up" issues. The feed-dogs seem on time. Top-tensioner seems to work fine too. Have 2x metal bobbin holders, tried with different bobbins (metal & plastic), tried all kinds of tensions; same result. I just can't figure out what causes the problem.
It would be nice to get a repair manual to check the settings / timings against my machine.
Has anybody a repair / service manual of the Bernina 1001? (the current Bernina 1008 model seems very identical)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
I just broke a needle on my 1001. I replaced the needle, tested it and have a bird's nest with the bobbin thread. I tried the user's manual, but it has nothing about this problem. I've been trying to make crisis masks and this is throwing a wrench in the project. Can you help me? And, what question am I supposed to answer? (See below)
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
According to the this website, the service manual for the 1020/1030 might be the same for the 1001/1008. However, this website says the 1020/1030 service manual is different from the 1000/1004/1005/1010/1015 service manual in direct contradiction to the previous website.
Here is the service manual for the 1020/1030: https://data2.manualslib.com/pdf5/106/10.... Hopefully, this will be of some help, as I've been unable to find a free copy of the service manual for the 1001/1008.
War diese Antwort hilfreich?
Bewertung 3
5 Kommentare:
Hello Tim; Thank you very much indeed !! Not all, but I do recognize in this manual similar components as in my 1001. The 1001 is, as the 1008, a fully mechanical machine and therefor I hope that I can solve the problem. For now I'll concentrate on the bobbin area. When slowly hand-cranking the machine the bottom thread is still slack when the top-thread tightens the loop. This causes the bottom-thread to lay as a rather loose chain of "S"-shapes (or weave pattern) on the bottom of the fabric. This happens regardless how tight I screw the bobbin-case tension-spring. The bottom thread seems only to be pulled tight at two occasions: 1) When the feed-dogs advances the fabric and 2) when a "hump", on the opposite side of the rotary hook strikes the bottom thread; but that happens after the top-thread has tightened the loop.
Hopefully with this manual I can now check all the settings & timings and perhaps find the culprit !?
Thanks a lot again and I'll let you know ;-)
Best regards: Endeavor.
von
Hi Tim;
Just to let you know that the 2nd part of the manual with the Bernina 1015/1010/1005/1004 & 1000 information was very helpful. I went through all the check-points and found only the hook-timing off by a 10-15 degrees. Adjusted the hook-timing according to the manual. Top-tensioner, bobbin tension, feed-dogs, needle position etc all fine ....... unfortunately the loose bottom thread problem persist, clearly visible when the maximum stitch length is chosen. The bobbin thread seems very loose when the hook wraps the top-thread around the bobbin-case. I just can't find out why or find any decent information how it supposed to be with, or the exact working of, a rotary hook.
Any further (rotary-hook) information is very welcome ;-)
von
Ha, I didn't even realize the second part of the manual was there. Good deal.
https://en.wikipedia.org/wiki/Rotary_hoo... - this has a good animated graphic of the rotary hook operation.
I'm not a sewing machine tech, but I can't see any other cause than something wrong with the lower thread tension. Look at section 54.1 of the second part of the manual that tests the lower thread tension. Do you have the weights they refer to to test the tension? If not, I would progressively tighten the bobbin case adjusting screw to see if I can't tighten up the lower thread. Worst case, try replacing the bobbin case.
von
Hi Tim; I tested / adjusted the bobbin-tension with a 5 gram weight. The problem stays., even though to a lesser extent, when I tighten the bobbin spring to the max. (at which the thread pulls really tight out of the case). Also tested the top-tensioner with a weight and that one was more or less "spot-on". To lessen the problem, and to pull the bottom thread tightly up ("through" the fabric), I've to sew with the top-tensioner set at 8-to-9 (out of 10).
I have a new bobbin case; same problem. I've seen the sketchy animation and understand the principle fully. I'm now trying to study / find information on how the the process exactly goes at every moment in time (per degree if you wish); hook position / bottom tension / top tension, needle-postion vs pickup-lever vs feed-dogs.
Agree, something happens at a certain moment time that causes too much slack in the bottom thread. The minor detail now is to spot that moment and what causes it. I'm still full of hope !! ;-)
We'll soldier on and I will let you know !
von
Did you solve this, Endeavour? I have a similar problem. You would think tension adjustment was the answer, and then it isn't.
von
How do I raise and lower the feed dog to my 1001 Bernina sewing machine?
Bewertung 0
3 Kommentare:
Hi Patricia; Your question is not 100% clear to me. To fully raise or to fully lower the feed dogs you turn the lower feed dog button; item 11, page 6 in the owners manual: https://media.rainpos.com/4690/bernina_1...
To adjust the feed dog height; down load this service manual and see point 65: https://data2.manualslib.com/pdf5/106/10...
The allan-screw is accessible via the bobin-"front-door"; top right-hand side .
Hope this helps?
von
Hi,
Here's a link to the page in the user manual that shows how to raise and lower the feed dog
von
Hello Patricia; Your question is not 100% clear to me. To fully raise, or to fully lower the feed dogs, you turn the feed-dog-knob, item 11, page 6 in the owners manual: https://media.rainpos.com/4690/bernina_1...
To adjust the feed dog height, you have to loosen an Allen-screw, accessible via the bobbin hatch, top right-hand side. For instructions read the service manual chapter 65: https://data2.manualslib.com/pdf5/106/10...
Hope this helps ........?
von
Antwort hinzufügen
Endeavor wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 4,353
