Laptop stops charging in game
My laptop is actually an Asus G75VW-DH71, the issue though is that whenever I start a game (Diablo III or WoW) it stops charging. I thought it may have been a bad power jack so I replaced that, but still same issue. As soon as I quit or close the game it goes back to charging. I am wondering if there is any way to fix this or is my MB toast?
Ist dies eine gute Frage?
Bewertung
0
Hi
Are you using the original AC Adapter or a 3rd party adapter?
If a 3rd party do you know the wattage of your current AC adapter? Look for the current and voltage rating that should be printed on the adapter.
The AC adapter for a G75VW should supply 19V, 9.5A. (180W )
Can you try another compatible AC adapter in case yours is failing under high load? (games are usually resource intensive and generally require more power than other programs your laptop may be just prioritizing the power distribution to meet your needs)
von jayeff
I have just replaced the AC Adapter, the previous one was a replacement that had been working fine for almost 6-8 months at least maybe longer. However the problem just popped up within the last month or so. For now, the problem has been alleviated and the computer has no issues. I can only hope it stays this way as the computer is still hefty enough to run games still coming out with little issues. Thanks for point in the right direction. I just didnt think it would be the adapter failing under load, though it most certainly looks to be the case.
von John Phillips
