Zum Hauptinhalt wechseln
Das ist die zweite Generation der Samsung Gear, eine runde Smartwatch, auf der als Betriebssystem Samsungs Tizen läuft. Die Gear S2 kam im Oktober 2015 heraus.
Gear S2 Classic Replacement Bezel Rings
Hi, I have the Gear S2 Classic (SM-R372), and somehow the top of my bezel, just the bezel's cover ring, came off while it was in water. Is there anyway a replacement top ring is sold anywhere?
I've only been able to find the entire bezel assembly, which on mine still works, and I don't want to buy an entire new bezel just for the ring.
Thanks for the help!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
Same problem here. Please let me know if you find this part. I bought one online and it was for gear s2. Too big
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
If you still have this I would buy it I need it for the S2
von
I called Samsung. They sell them for $90.00, which is more than the watch is worth now.
Bewertung 0
Hi could you tell me where you found it I've been looking for one can't find it I don't need the ring I just need the bearings maybe we can buy it together and split it thank you
Bewertung 0
Antwort hinzufügen
Arjun wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 1,520
