Zum Hauptinhalt wechseln
500 series DSLR camera developed by Nikon. Released in February, 2011.
20 Fragen Alle anzeigen
doesn't fully shut off (coolpix b500)
hi,
so my Coolpix b500 (they didn't have that in option) isn't shutting off properly, when i shut it off the green light still is on and the battery's die soo fast! (I use lithium) I have check every setting and have looked on the internet but I cant figure out how to fix it!
please help!!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
Where is the solution to this problem?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I have this issue too. What I do is turn it off, put the lens cap on then turn it on. A message will come on the screen to turn it off then on again. Once I turn it off this time the light goes out. Hope this helps
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
I have done this before but wasn't sure if it was okay for camera and if it fully shut off, thanks!
von
Thanks Karen. I was having the same problem but your solution fixed it. Thanks again.
von
Well done…troubled me for ages…works! Thank you..
von
This method seems stupid to me. To use an error action to make the light go out. What does Nikon say to do to get the green light to go out when you shut the camera off. That should do it on the B500.
von
Antwort hinzufügen
heusscarolyn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 13
Insgesamt: 1,797
