Zum Hauptinhalt wechseln
Burnham steam boiler PIN4SNI-ME2, PSI valve replacement
I have the part, but is not sure how to uninstall old and install new. Do I simply unscrew it from the body of the furnace and install the replacement PSI valve. Anything I should be aware of (except, of course that the furnace needs to be off and cold when I do this)?
Many thanks, SE
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Here’s the service manual for your boiler Burnham Independence Boiler
Pressure valves are a very tricky thing. If not installed properly you can cause big issues!
I strongly recommend you get a trained heating technician in to install it for now. If you really want to learn go to a good vocational school to study heating.
Just the other day a home near here blew up! The homeowner tried fixing his boiler and now he’s homeless!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
sam engelstad wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 196
