Zum Hauptinhalt wechseln
Repair guides and support for the 5th generation Honda Civic, first released in late 1991.
20 Fragen Alle anzeigen
Why does my motor fan not work?
my car was over heating so i replaced the thermostat.... turns out the fan does not kick on...how do i fix this?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
There is a switch in your thermostat housing that may not be working. You can use a multimeter to see if the switch closes at temperature. Also check the fan motor itself. I used to do it by applying power directly to the electric motor to see if it works. Not a terribly expensive or tough repair and should be doable in the drive way :-)Let me know if you need a copy of the service manual for the cooling part. Good Luck
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
good answer +
von
I thought so, but I guess Sara Perez did not ;-)? Have not heard back to see if it worked. It would be nice if we would all get a bit more feedback just to make sure that our advise worked or what else is needed....Oh well ;-) Thanks remacberlin
von
I am not the original person who posted this but I have the same problem, I jumped the thermo switch plug and the fan came on,
Bewertung 0
Antwort hinzufügen
Sara Perez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 6,663
