Zum Hauptinhalt wechseln
Repair and disassembly guides for the Compaq Presario CQ40.
Can I use ethyl alcohol?
can I use ethyl alcohol 70% to clean my device ?
Ist dies eine gute Frage?
Bewertung 2
5 Kommentare
ethyl alcohol is for drinking. A 70% would be 140 proof. Just what do you have?
von
I bought it from the pharmacy It's used for medical purposes And product name is (PURE Nautre's Purity)
von
If its pure, then you should use it. My answer is YES!
von
I would strongly recommend using isopropyl rubbing alcohol as, it does not leave as much of a residue as ethyl alcohol can. Electronics are very sensitive.
von
Thank you for helping me. I will use ethyl alcohol in this period then Later I will try to get isopropyl alcohol to avoid any damage
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
You can, but the high vapor pressure means it will evaporate much quicker than an alcohol more suited to cleaning like isopropyl. Make sure it doesn’t contain any other chemicals that could be left on the device when the alcohol evaporates.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
thanks for answering
von
Please look at this question: What are Professionals Using for Screen Cleaning
Bewertung 1
Antwort hinzufügen
Amr Ateef wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 633
