Zum Hauptinhalt wechseln
Erschienen im März 2016, Modell SM-G891A
"Moisture has been detected" issue.
All of a sudden my S7 active started to claim that “moisture has been detected” and that I had to remove the cable and dry the charging port. The phone has never been exposed to water. I followed all the advice I could find online:
·       Stored the phone in basmati rice for an entire week
·       Used hair drier for over 3 hours blowing straight into charging port and open SIM card port
·       Left it in the sun for a few hours constantly ensuring it never overheated
The problem persisted and the battery ended up dying. I then followed the disassembly guide found on ifixit.com and removed the piece of board that contains the charging port. I then cleaned it and removed any sign of corrosion (which there sure was). Now re-assembled the phone refuses to react to the power button as well as to the charging cable and remains completely dead. Any advice? Can I buy the piece of board with the charging port from anywhere?
Thanks for your answer!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@bikeoholic absolutely can you get that part. Do a online search for “Samsung Galaxy S7 Active SM-G891A USB Charging Dock Port Mic Flex Cable “ or check this place It is in stock and not expensive. Also, remember to change your battery as well.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Samuel Kummrow wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 1,032
