Zum Hauptinhalt wechseln
The Panasonic KX-TGEA20 is a phone accessory that is compatible with Panasonic devices. It features a 1.8-inch LCD display with a resolution of 103 x 65 pixels. The navigation key allows for easy and convenient use of the phone.
Phone goes off after one incoming call
Phone will only ring once and then goes off
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare:
Hi,
Just clarifying.
The phone rings once and then stops ringing. Is this correct?
Is there anyone there if you answer it after the one ring or not?
Can you call out OK and if so is the line noisy?
von
My phone rings off after one ring no one there if they ring back it might take a few times before we can answer them We can ring them there is no noise when we do
von
Hi,
Have you got access to a corded phone that you can plug into the phone line instead of the Panasonic just to check if the problem is in the Panasonic phone or whether it is connected to your phone service?
von
Einen Kommentar hinzufügen
1 Antwort
Maybe it’s a battery problem. You might want to check it if it can still supply the power needed. If not, you may consider replacing the battery?
Cheers.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
sheilajohn-49@hotmail.co.uk wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 1,232
