Zum Hauptinhalt wechseln
14" laptop introduced in 2013
8 Fragen Alle anzeigen
5 beeps and 5 beeps.
I searched and found out that the system board has a problem when there 5 beeps and then 5 beeps. How do you fix the system board?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Generally, you cannot fix motherboards due to the soldered components on the motherboard. However, you can replace the motherboard even if it is a laptop. First make sure to note what screws are holding the bottom cover in place and use the required tools. Also, make sure that you are 100% sure that it is actually the motherboard even if the information provided to you is highly reputable.
Generously,
Richard Smith
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Mike A wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 20
Insgesamt: 3,761
