Zum Hauptinhalt wechseln
The Odyssey was introduced in 1994 as Honda's first minivan — based on the Accord platform, with a 4-cylinder engine, all-disc anti-lock braking, all wishbone suspension, and a four-speed automatic transmission with a steering-column-mounted shifter and a hill-hold feature, marketed as Grade Logic.
6 Fragen Alle anzeigen
Why is my transmission light flashing
The transmission system doesn't select well whenever the drive light on the dashboard goes off
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi,
Check that ATF (automatic transmission fluid) level in the vehicle is at the correct level and that it is clean and doesn’t smell burnt at all.
The transmission fluid should be replaced every 48,000 Km (30,000 miles)
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Okechukwu Chukwu wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 173
