Zum Hauptinhalt wechseln
The Dell Inspiron 15-7567 laptop was released in 2017.
Do you sell a laptop battery?
My laptop's battery just inflated. I need to replace it. Do you sell battery for dell inspiron 15 7567?
Replace a 6600 mAh battery compatible with select Dell Inspiron 15 model laptops. 11.4 Volts (V). Bild
Produkt
Dell Inspiron 15 357F9 Battery
$69.99
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @jshdlssnts ,
Unfortunately ifixit does not have the battery you are after.
Try searching for Dell 357F9 to find suppliers of the battery. This part number should also be on the battery in your laptop if you wish to verify that it is compatible or not. It is used in a lot of Dell Inspiron 15 7000 series laptops.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
@jayeff do you know where i can find one?
von
@jshdlssnts
Here's just one supplier
As I said just search as described above to get suppliers that suit you.
This is what I got when I searched.
von
Antwort hinzufügen
Joshua Delos Santos wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 160
