Zum Hauptinhalt wechseln
Die sechste Generation des von Google designten Android Smartphone, welches LG produziert. Modell LG-H790. Veröffentlicht im Oktober 2015.
Thermal Pads for Phones
Hi guys, so right now I’m doing a screen repair on a Nexus 5X and I’ve realized that there is a thermal pad on the phone’s screen assembly (see picture). I don’t think I can transfer this pad without breaking it so I was wondering which thermal pad should I buy.
Is it fine to use pads that are for PCs eg. GPUS?
Should I be buying 0.5mm thickness or 1mm thickness?
Are AliExpress/eBay thermal pads fine to use.
eg. ++https://www.aliexpress.com/item/32716660...
++https://www.aliexpress.com/item/32839304...
Thanks.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
The thermal pad on the screen is the yellow square.
von
Einen Kommentar hinzufügen
1 Antwort
If you have a lot of space use 1mm which would dissipate the most heat but if you only have a limited amount of space then go for 0.5mm and I think you should read the reviews before buying the thermal pads
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Hairy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 32
Insgesamt: 585
