Zum Hauptinhalt wechseln
THINKPAD T520: Top Tier Performance and Portability.
Computer is on but screen black?
My laptop worked yesterday. Today I attempted to turn it on as usual, pressing the power button. It made all the usual noises. On startup, It makes a beeping noise, but that is normal. Today the screen is completely black. I can tell it’s on. The fans are running and the light is on. Still, the screen is black.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
DiamondWolf Gaming  connect an external monitor. If that works you know the issue is with your display. If it does not then it could be a GPU (motherboard) issue. Also while your computer is on, in a darkened room, shine a flashlight beam at an angle against the screen. See if you can make out your menu etc. If so you know it is a backlight issue.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
DiamondWolf Gaming wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 376
