Zum Hauptinhalt wechseln
The Sony Bravia KDL-50W685A is a television model produced by Sony.
6 Fragen Alle anzeigen
Intermittent shutdown with flashing RED led 9 times.
Sony Bravia KD-65X9000B occasionally shuts down with main LED flashing 9 times ( then 3 seconds and repeat).
Sometmes it will restart with remote but mostly needs complete power removal for 15 minutes for restart.
Any ideas what 9 flashes means with this Sony ?
Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Facing the same issue
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi @aksal60 ,
According to the service manual a 9 blink error code indicates a problem with the TU board (tuner board). The manual is for both the 55” and the 65” models
Here’s a poor image of the blink error code chart and the location of the TU board.
(click on image to enlarge for better viewing)
The service manual can be viewed for free online but it is low resolution, so some sections are hard to make out. Also there are no schematics in the manual.
To download the manual you have to pay for it. To move through the manual you have to select the appropriate page number below the document and click on Go. There are 127 pages in the manual.
Page 71 of the manual shows the location of all the screws that hold the back cover.
Hopefully a start.
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
Nice one - thankyou. Was thinking a PS fault but maybe not so now.
Thanks again.
von
Has anyone come up with a fix or solution for this problem - I have the same problem.
von
I am also facing the same problem with Sony 49’’
von
I have the same problem on a KD-70X8500B
This model has a seprate tuner board.
I removed the tuner board and powered on still get same problem.
Can sony run without the tuner board if there seprate from the logic board?
I wish there was a list of things to check if you get the 9 blinks? It says what the possible issues could be, power board?
Anyone know the answers above ?
Bewertung 0
Antwort hinzufügen
Daniel Fleming wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 22
Letzte 30 Tage: 81
Insgesamt: 4,071
