Zum Hauptinhalt wechseln
Die Sony Cyber-shot DSC-HX9V ist eine Kompaktdigitalkamera mit 16.2 megapixel Auflösung. Die Maße sind 105 x 59 x 34 mm(BxHxT).
11 Fragen Alle anzeigen
location/ replacement of internal Li ION battery
My question is similar to others for different models of the Sony Cyber-Shot camera
the date/time need to be re inputted each time the main battery is removed/replaced.
I wish to be aware of the exact location of the battery as :after checking out the manual for different models the design is different .
making the disassembly and repair troublesome .
I have used your site for many repairs of apple phones and ipods but now I am in different territory.
Any help would be greatly appreciated.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Hi @videophile999 ,
Here’s an image showing the location of the backup battery Sony part #1-756-813-11 (supplier example only), taken from p.18 of the service manual for the camera
(click on image to enlarge for better viewing)
The manual details how to dis-assemble the camera and it appears that the battery is soldered onto the MS-461 board. (Sony part #A-1818-410-A - I can’t find an image of the board which would help but once you have accessed it the battery would be quite obvious)
I only found a few supplier listings when using the part number to search online for the battery. You may have better luck.
Hopefully this is of some help.
War diese Antwort hilfreich?
Bewertung 2
5 Kommentare:
Thanks for the assistance and the image .
Looks like almost a full disassembly
what a lucky guy I am .
Now to find a supplier of the battery
Again THANKS
von
@videophile999
If you can't find one by using the "Sony part number" usually most batteries will have their type or model number stamped on the battery.
So if you can't find a suitable supplier it may be a case of having to access the battery first and seeing if there is a type number on it and then searching for that.
EDIT:
On a hunch I searched for 175681311 which is a number shown in the supplier linked above and came up with this so it looks like the number is about right to use for searching and there are a lot more suppliers shown when searching this way, rather than using the Sony part number
Your model is not listed in the Sears link above but the battery is used in a lot of Sony cameras it seems, so highly likely it is the one
Good luck
von
Sister had a broken camera that had been driven over by her car .
Dismantled camera and removed battery .
Replaced it into my camera All fixed and working
And as per the ruling of the gods . I have a spare screw with nowhere to insert it
Thanks you jayeff
von
@videophile999
It mightn't be a problem if the screw is from your sister's camera and not yours.
Cheers
von
From the service manual it looks as if it is clipped to the MS461 board, not soldered, and is not supplied with the board so must be available separately.
Bewertung 0
5 Kommentare:
Hi @jonmay99328,
Looking at images of the battery online to me it looks like it has solder tags.
image 1
image 2
von
Pity! My perfectly good camera needs this replaced too so i shall have to visit a sony shop.
von
I see the Amazon listing for this battery says it weighs a kilo !
von
Hi. I have dismantled two cameras. The battery is definitely soldered to the board. As to supply I was not able to find any suppliers here in Australia. I suspect that is was a "one off" that was made specifically for this camera, but in the U.S.A you may have better luck. Even if I could obtain a battery from the "states" the shipping/postage is so high as to render the project nonviable..
Good luck
von
@videophile999
Check if there's a battery model number on the battery itself and search for that number battery.
Sometimes if you can't find it using the device manufacturer's part number, using the battery model number will find it.
Just a thought.
von
I am not sure if this will be helpful for some but I found this on a Sony archive.
The battery can be found by looking for MS614SE. Have not tried it yet but seems to be the same one shown in the manual.
Bewertung 0
1 Kommentar:
Antwort hinzufügen
Allan Mason wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 21
Letzte 30 Tage: 120
Insgesamt: 2,031
