Zum Hauptinhalt wechseln
Device repair and information for HP's line of Pavilion 15" laptop computers.
Power button lights but nothing happens.
Hi laptop was working fine then had booting issues where it would get to home screen and auto reboot. Managed to get to repair and started a windows reset last I saw it was 47%, but I had to leave. When I returned black screen power button was on but nothing. Tried turning off and on, again power button lights but no fan noise and no screen lights. I have tried a reset where I took out the battery held power for 30s and replace battery but no change. Power light is on when charging but no other lights even caps and mute lights not working.
Ist dies eine gute Frage?
Bewertung 5
3 Kommentare
@kmonkey78 start off by checking if you can still access the BIOS. YOur issues sound HDD related. To get into the BIOS start tapping Esc- immediately after pressing power button. you have to be pretty quick about it and may take more than one attempt. Let us know what you get. Should you make it into the BIOS check your boot order and see if your computer sees the HDD. If not try to boot from a bootable USB stick or LINUX Distro etc.
von
@oldturkey03 hi thanks for the reply I have tried your suggestion 10 times but nothing happened. No back-light on screen I had the case off and no fans or any noise of anything working.
von
Hey, we are having the same issue here.. did you fix the problem buddy
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
If you can remove the laptop battery, do so, unplug the power, and press and hold the power button for about 20-30 seconds with nothing else plugged in. This will drain the flea power off the system. Once you've done that, put the battery back in, plug it back up and try to turn it back on and see what happens.
If you can't remove the battery, unplug it and press and hold the power button for 1 minute with nothing plugged in and repeat the same steps above.
It's important to not have anything else plugged in during this time like an external keyboard, mouse, monitor, etc. as we want only the charger and the battery to be the source of power for the unit.
If the drain residual electricity way is not working in your case, please kindly check out some posts of Methods For Fixing My HP Laptop Won't Turn On.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Hey Albert! Thanks for the advice. It was well written and easy to understand, and…… most important of all….. It worked! Thanks!
von
Hey! I did this and it still didnt work only the power button cuts on and now nothing cuts on what Should I do?
von
Antwort hinzufügen
Nick ball wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 31
Insgesamt: 6,544
