Zum Hauptinhalt wechseln
9th generation Honda compact car.
20 Fragen Alle anzeigen
Car "Jerks" while accelerating
I've been noticing this pretty much ever since I bought the car. When I accelerate moderately from a stop or slow speed (5 to 10 km/h), I can feel the car jerk fairly harshly - enough to throw you forward in your seat. Right before RPMS start to get around 2500 - 3000. This doesn't happen if I accelerate slowly, if I'm already moving at a decent speed and I floor it, or when I'm decelerating. Only when I accelerate from a stop or very slow speed. I have a 2014 Civic Coupe with the 1.8 and the CVT
I've changed the CVT fluid with an OEM equivalent replacement from partsource, and it seems to have mostly gone away for the first ~50km, but not long after that, it's back as if I haven't done anything. I've put around 1,500km on the car since I've changed the fluid and it feels as if I haven't done anything now
My car has 143,000km, and since I bought it used, I have no idea when the fluid was last changed. I asked the previous owner and they didn't remember getting it done.
What can I do to solve or improve the issue? It's quite frustrating and uncomfortable for everyone in the vehicle.
Thanks everyone :)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
The questions to ask are; is this a cvt or engine problem? I would search Honda forums for members that may have experience and answers. Continuously variable xmissions can be problematic with completely different issues unrelated to standard electronically controlled xmissions. Xmission specialists familiar with CVTs may only exist in dealer departments with fewer in xmission repair shops. Engine problems are relatively easier to diagnose and troubleshoot compared to cvt problems.
von
Well I'm pretty sure its a transmission issue, as it went away completely for a bit after a fluid change
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
For anyone that needs the answer, it actually ended up being a vacuum leak. The clean air intake hose had a big crack in it, which wasn't visible until I started messing with it. If you're having a similar issue, start there.
War diese Antwort hilfreich?
Bewertung 7
5 Kommentare:
Glad you found the solution and sharing it to close this thread.
von
Ik this is an old thread but I have the same problem there was a big tear in the clean air intake. Immediately after putting the new boot on, I have excessive pressure in my crankcase, I replaced the pcv valve and cleaned the hose that goes back to the intake but I still have excessive pressure. The compression test was fine so far but I don’t want to blow my rings. Any ideas lol?
von
did you ever find this issue. i cleaned the throttle body and replaced hoses still getting bad jolt at 1800 rpms
von
Old threads die hard. Checked for all types of visible leaks - found none. One electrical diagnostic specialist said there was a problem with the ECM.
Vacuum tests (not compression) shows a slight (15%) reduction in cylinder 2 in comparison to remaining cylinders 1, 3 & 4. An engine specialist friend said the issue maybe due to a combination of 2 factors - the CAT converter failure (no CEL yet) plus cylinder 2 vacuum issue. We cut open the CAT, and truly 60% of the CATs engine exhaust port side face was damaged causing blockage. Minor changes in exhaust-flow blockage within CAT can send erratic voltage to ECM, which in turn sends erratic signals to the EGR valve, fuel injectors/everything. Thus EGR valve opens/closes erratically within the 1500-1800 rpm range, which could explain bad jolts in this range (during acceleration). Cannot afford a new CAT now. So, I'm trying to modify the air intake resonator to absorb some back pressure on non-exhaust side i.e. on air intake side. Initial results are promising.
von
The modification of the intake resonator did not yield the desired results; jerking continues; have ordered a new low-priced ($45) after-market EGR valve from AULINK on amazon; if the jerking goes away for 1 week (300 miles), then an OE Honda EGR valve part # 18011-RBJ-000 will be ordered for $253 on Amazon. If the jerking continues with the new after-market AULINK EGR unit, then have to replace the CAT.
von
does this car have individual coil packs for each cylinder that is what fires your plugs is your engine light on if not buy a cheap analyzer see what it says if you have multiple coils and one bad one it will make your tranny run eratic
Bewertung 0
Antwort hinzufügen
Ethan Leroux wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 24
Letzte 7 Tage: 120
Letzte 30 Tage: 507
Insgesamt: 19,974
