Zum Hauptinhalt wechseln
The Mi 10 is a mid-range smartphone by Xiaomi released February 2020. It has a 6.67" AMOLED display, a 108 MP main camera, an in-display fingerprint sensor, a 4780 mAh battery, and runs on a Qualcomm Snapdragon 865.
C port is not fitting the charger
My c port is not fitting in the c cable anymore.. It is so loose.. I tried cleaning the c port of phone but doesnt got solved
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
You most likely need the port replaced on the device as it appears that it is damaged based on your description of the issue. You can try a different cable first to see if the cable you are using is what is damaged.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Anuroop P.Satheesh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 27
Insgesamt: 376
