Zum Hauptinhalt wechseln
My battery is not being read correctly
It says 16% but its actually at 1% or dead, the batteries are not swollen.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @nytryder26
Just because the battery is not swollen, that doesn't mean that it is not faulty or hasn't failed.
Try replacing the battery and then check.
You need to start with a known good battery rather than trying to find a problem in a device with a battery which may have an unknown problem, still installed.
If you get the same result with a new battery then the problem is not the battery
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks for the help!
von
Antwort hinzufügen
NR26 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 237
