Zum Hauptinhalt wechseln
The fourth generation Nissan Altima (chassis model L32A) was announced at the 2006 New York Auto Show on April 12, 2006. It was the first vehicle to use the smaller Nissan D platform, with a new front and upgraded rear suspension.
07 Nissan Altima Acceleration issue
My Altima has 118k miles, was jerking and hesitant when going into drive and reverse, so I parked it. It had a lean code p171 and p300 misfire code so i changed spark plugs and coils, valve cover and gasket, MAF, cleaned throttle body and checked all the fuses. It still does not accelerate, but the RPMs will go high (past 4k) until i let off gas pedal. Goes into all gears just fine, reverse has no issues now, but when i put in drive it feels like its in limp mode. Checked the alternator and its fine, also car has a new battery too. Im at a loss. I still owe $4k on this car and was quoted $2k for a used installed tranny. I really need help!!! Oh i had a TPS code and a throttle actuator code come up 2101, 123 & 223 then realized I had a loose sensor on the throttle body. I cleared the codes and check engine light went off but still doing it. Please Help!!!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Are you sure its not in limp mode? Also it sound like the auto transmission may be slipping.!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Robin Shepherd wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 161
