Zum Hauptinhalt wechseln
Veröffentlicht am 22. September 2017. Modell A1864, A1897. Erhältlich als GSM oder CDMA / 64 oder 256 GB / Gold, Silber und Space Grau.
20 Fragen Alle anzeigen
Why is my screen dark
i have a black spot on my screen and its really bugging me. Pressing on the black spot will make it worst and i dont know what to do
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
hello Muhammad
If you have a black spot on your iPhone 8 Plus screen and pressing on it makes it worse, it is likely a physical issue with the display. This could be caused by a number of factors, including:
  1. Dead pixels: A dead pixel is a pixel on the screen that is no longer functioning properly. This can cause a black spot or other visual abnormalities on the screen.
  2. Physical damage: If your iPhone has been dropped or otherwise physically damaged, it could have caused damage to the screen that is causing the black spot.
  3. Moisture damage: Exposure to moisture or liquid can cause damage to the display and result in black spots or other issues.
  4. Electrical malfunction: In rare cases, an electrical malfunction could be causing the black spot on the screen.
Unfortunately, if the black spot on your iPhone 8 Plus screen is caused by a physical issue, it will likely require a screen replacement. You can contact Apple support or an authorized repair center to schedule a repair.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Muhammad Nasrullah wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 43
